Any images of the result from that?you don't! You print them.This seems really nice. Where do you source the cases from?![]()
good question. Would like to jump in here for 3 cases aswellwhere or whom can i get 3 cases printed for 3 games.
yup: PGM single game PCB assembly and troubleshootingAny images of the result from that?you don't! You print them.This seems really nice. Where do you source the cases from?![]()
http://daifukkat.su/hacks/ketarr/What’s the deal with the trap version? Quick google searching hasn’t really told me much
I will like to know also, is it to not have to set the jumpers/switch for the different revisions/dual boot? So just make a cart for each one?? Like Ketsui original cart and then one modified by Trap??I'm curious why people are buying 4 of these... is there a game other than the 3 cave releases that I missed?
Cave made DDP DOJ, then made DDP DOJ Black Label. The original PCB for Black Label let you switch between "White Label" and "Black Label" on boot though an on-screen menu.Also, which versions of DDP still have the issues? Differences with the versions? I see original, AMB. theres another dual one, think Im getting them mixed up.
i keep hearing that, but my fluffy repro worked fine on While Label mode (it is dual boot with black label). Maybe the amb conversions don’t work? I am not sure where it was supposed to break, fifth boss? but this was the white label ending i recorded, and let it run into attract mode so you can see it’s white label. I suck so if it’s like a “second loop” thing then this is invalidand similarly the White Label Version on the Black Label cart doesn't work.
My logic was simply that I read that you couldn't use chip sockets if you wanted to use any sort of case so I was planning to have one set of boards with sockets so I could test I had everything programmed correctly without having to solder/desolder chips before then soldering them in permanently.I'm curious why people are buying 4 of these... is there a game other than the 3 cave releases that I missed?
PGM single game PCB assembly and troubleshootingInteresting. I've never even got to the point of gameplay. which patched version of the ROM are you using, and which mobo do you have?
