traplicious
Noob here.
I just got a MvC A and B board from a seller on Craigslist.
It was suicided and I am trying to install phoenix roms. I already took the battery off and cleaned everything up.
I went thru and rewrote all of the eproms using a decrypted MvC set, which I tested in FBA and worked, said Phoenix Version and everything.
However, when I start it, it shows a screen that looks like an old Windows taco screensaver, then shows a bunch of garbled messes, then just shows white.
Here's a link to a vid: https://drive.google.com/open?id=0B48VhoX6xWKUZlVZNE9UeFdfb2QyeFNDbjk5ZTlmT1RSVmVV
I burned the CPS2 tester and put that in, and it said that everything it checks tested fine.
I tried shorting the pins as well and nothing.
Any thoughts?
Full disclosure: when I was writing some of the eproms, I had to select M5M27C102K instead of M5M27C402.
The writer I'm using didn't have that one. It did let me write to it though
. Is there another chip similar that would work instead?
Any thoughts?
