GeorgeSpinner
I asked about this back in December and never heard anything.
This week, I decided to make my own.
It wasn't very difficult at all.
I used the Adafruit Trinket Mini 3v/5v which cost me around $10.
I tested it out on MV1C and MV1B hardware with the Series 1 and Series 2 Banana carts.
It worked great.
It only requires 4 wires to be soldered. I chose to solder right to the JAMMA connector, keeping my PCB clean.
I wired it up to my supergun, so it's portable.
If you modify the code and eliminate the ability to load the standard 161 in 1 menu, you could cut it down to 3 wires.
If you aren't familiar with the Adafruit Trinket Mini 3v/5v PCB you can check them out here.
The trinket is compatible with most Arduino libraries.
I had to flash a different bootloader onto the Trinket because it was taking 3 seconds for it to run any code.
I needed to use an Arduino Uno to flash the new bootloader.
I link the new bootloader in the README.
You can get the code from here if you are interested: https://github.com/GeorgeSpinner/Adafruit_Trinket_Mini_Auto_PICKnMIX
It worked great.
