It is good newsManaged to find myself a 19" WG tube. So we should have one question answered soon![]()
I have sent a message about Color codes yesterday
Color match codes, I borrowed a paint scanner from a buddy, nice little tool.Yes please.If you can find the code, i can try to find it and test it.Not a problem, just need to know what you have access to/brands/etc...so I can get you the code.We need powder coat code my friend. Not automotiveI can try to do a color match at one of my local bodyshops, @hursit what brand auto paints do you have access to /use so I can compare to what I get locally, I can definitely get you the yellow and green.maybe @Derick2k or @Arcade game who I know do have them might be able to assist?
There are always some color catalog for the painting. Maybe you can find one of them and compare it with your minis
Pantone@Derick2k I was asked to try and match them to Pantone.
Not as easy here since none of my screens are calibrated for that sort of thing and it's kind of guesswork :/.
Ok, let me check if this tool does that while I still have it.That's what I was sent links to! I don't know a damn thing about color matching. Just trying to eyeball against like three screens and hoping to hit the right one, ha.Pantone@Derick2k I was asked to try and match them to Pantone.
Not as easy here since none of my screens are calibrated for that sort of thing and it's kind of guesswork :/.Ok, let me check if this tool does that while I still have it.
Well there should be a converter for the color codes I provided to pantone if thats what he needs.That's what I was sent links to! I don't know a damn thing about color matching. Just trying to eyeball against like three screens and hoping to hit the right one, ha.Pantone@Derick2k I was asked to try and match them to Pantone.
ralcolorchart.com/ral-design/ral-180-80-30
Yes, these are the colors that I posted above that match my cabsralcolorchart.com/ral-design/ral-095-90-40
Wonderfull, that means we know the color codes. I will ask to factory for these colors. Maybe they have or they can make it for meralcolorchart.com/ral-design/ral-180-80-30Yes, these are the colors that I posted above that match my cabsralcolorchart.com/ral-design/ral-095-90-40
What catalogs do you have? I will see if they if these codes can be converted to those.Hello guys.
There are some bad news about of the colors.
Thanks to @Derick2k we have found the ral codes ( pink is missing)
These color codes are in the D2 Ral Catalog. They dont have that catalog in TURKEY. It is expensive catalog.
Anyway i have talked some company and they Said they can produce these colors but it has to be at least 1000kg each of colors. Thats very huge and very expensive.
I will try to find out other companies
In Turkey, companies has K7 catalog generally. These codes are not in K7.What catalogs do you have? I will see if they if these codes can be converted to those.Hello guys.
Gotcha, the K7 is part of the RAL classic color catalog with 200+ shades/colors in place since the 1920s, the RAL D2 is a newer color catalog which has about 1800+ shades/colors created about 20+ years ago. So its going to be harder/impossible to match the newer color to the old K7 catalog. I guess you would have to get a powdercoat place to match RAL D2 codes and either make it or import it from somewhere.n Turkey, companies has K7 catalog generally. These codes are not in K7.
Anyway i will update the infos after i talk with other companies.
Yes exactly.Gotcha, the K7 is part of the RAL classic color catalog with 200+ shades/colors in place since the 1920s, the RAL D2 is a newer color catalog which has about 1800+ shades/colors created about 20+ years ago. So its going to be harder/impossible to match the newer color to the old K7 catalog. I guess you would have to get a powdercoat place to match RAL D2 codes and either make it or import it from somewhere.n Turkey, companies has K7 catalog generally. These codes are not in K7.
Do you have the RAL D2 code for the pink color?Yes exactly.The main problem is the producing of that colors. They want 1000kg. But im sure i will find a wayGotcha, the K7 is part of the RAL classic color catalog with 200+ shades/colors in place since the 1920s, the RAL D2 is a newer color catalog which has about 1800+ shades/colors created about 20+ years ago. So its going to be harder/impossible to match the newer color to the old K7 catalog. I guess you would have to get a powdercoat place to match RAL D2 codes and either make it or import it from somewhere.n Turkey, companies has K7 catalog generally. These codes are not in K7.
The problem is not the color code.
