Sweet. Are you able to source those for US too?Easy for you to say. You do know that the K7000 and compatible tubes are absolutely impossible to find in Europe? @hursit would be screwing everyone in Europe over if that were true.Forget about the 20" MTC-9000 too. The repro is designed for the WG 19" K7000 and only the WG 19" K7000.
Anyway, I remembered wrong, the mounting points are actually different:
Easily fixed with a drill though.
As for the width, the side bars are removable if needed and you could put a smaller tray for the chassis if those are issues. As for depth, the MTC-9000 with a TTD A48 tube is actually shorter.
If a K7000 with the original frame fits in the repro cab, give me 15 minutes and I'll throw a MTC-9000 in. If the cab comes with its own frame, then this is completely inconsequential. A 48cm tube is a 48cm tube. A Hantarex MTC-9000 will fit, end of.
Because it bears repeating.If the cab comes with its own frame, then this is completely inconsequential. A 48cm tube is a 48cm tube. A Hantarex MTC-9000 will fit, end of.
I won't be sourcing them for anyone. I need the ones that I already have.Sweet. Are you able to source those for US too?
This made me relieved a bit
Awesome! Are you going to make a different frame for the Hantarex monitor in EU or can that same K7000 frame be used on MTC-9000 too?
We have checked it with @deibit and it looks like Hantarex is not compatible with original mini cute design because of the Depth of the Tube.The tube will just bolt on to the frame, so doesn't matter which monitor you use.
Nice job, @hursit!
How the hell is that possible? With no frame, surely it depends on just the depth of the tube? Again, for the 6th time, a 48cm tube (20" European) is a 48cm tube. A 51cm tube (21" European) will not fit, not because it's too deep (it probably isn't), but because the diagonal is too large.Well, the MTC9000 is from hantarex![]()
It’s just that the Polo/2 and the Polo/3 might be too deep for the case.
