zero238
The cutes require sacrifices!!! It shall be done...
@Epyc did some tests on his ASUS VB199T-P that looked great.If I can't find a CRT monitor, what type of LCD should I be looking to get?
I got one of the ASUS VB199T-P you tested, so if I cant find a decent tube, will throw this in while I source one.I’m currently working with @hursit on seeing if we can design an adjustable mount to accommodate 17” and/or 19” LCD monitors. Nothing concrete yet, so no promises.
I fixed it!Neo1925.
This would be 100x easier and you'd likely end with a nicer looking image.Or would it be better to go with a PC monitor and a device like the OSSC?
I hope.
I hope it does, picking it all up this weekend, so ill open the tv up and check, cant complain, $125 for both is not a bad deal I think.@Derick2k if the pins match on the neck, you shouldn't have to swap yokes. *Note this isn't general tube swap advice, just k7000 and US 19" TV advice*
Gotta find the Ultracade UVC and get an Xbox360 VGA cable so you can downscale to 15k. Pretty sure that's how most folks run 360s on arcade CRTs.Great news all around! I knew you guys would pull through, sometimes you gotta have a little faith in people. Im on the fence on ordering another one but also might just wanna wait for those repro Neo 19.
Potentially stupid question here, I'm still looking to get the monitor business sorted out but wanted to ask about multi sync. I know the k7000 is a 15 khz monitor but I wanted to hook up my japanese xbox 360 to it. Are there any down scalers we can use for this purpose? Or would it be better to go with a PC monitor and a device like the OSSC?
Again much thanks for your work people that are making this possible.
That's the hard bit right there. They used to be everywhere and cheap! Not so much nowadays.Gotta find the Ultracade UVC
That’s how I’m doing it..works great.Gotta find the Ultracade UVC and get an Xbox360 VGA cable so you can downscale to 15k. Pretty sure that's how most folks run 360s on arcade CRTs.Great news all around! I knew you guys would pull through, sometimes you gotta have a little faith in people. Im on the fence on ordering another one but also might just wanna wait for those repro Neo 19.
https://www.google.com/search?q=xbox+360+uvc+ultracade
*puts the two I own into my closet quietly*That's the hard bit right there. They used to be everywhere and cheap! Not so much nowadays.Gotta find the Ultracade UVC
