Pre-Order For Mini Cute Production
Alright update on buttons/sticks/PSU. They are EXACTLY $100, there is absolutely NO room whatsoever to wiggle on that, even buying everything in bulk. I can guarantee you, you will not get a better price all said and done, once everything is packed together and whatnot. If you are going for stock buttons/sticks and want a recommended PSU, highly recommend you pick these up to pack with the cab.
I'm not sure if I'm going to do a group order on speakers, I'm already $8,000 out of pocket advancing on the parts, and right now I'm already EXTREMELY tight on finances with several containers open. If there's interest, I might arrange something after the cute order ships and financial restrictions loosen up.
Any way you can make sure there's a safe way to secure a package with buttons/sticks/PSU to the crate for when I ship them out? I'm not going to be opening any of these crates for obvious logistical reasons
I'm in east Oregon. If Cereth stages the cabinets in Reno I am considering making the 7 hour drive - if that is an option.
It's an option, but would be more affordable to join in on a group shipment, since I'd be going through anyway
Side note since I don't think I've really mentioned it publicly yet, any orders completed after the container has been paid for in full will be $150 more per cabinet. They will be $1,750, and include the buttons, sticks, and power supply. The price of $1,500 per cab is only for pre-order. Once payment is complete for the order, it is no longer a pre-order. That price reflects that the pre-order helps facilitate the order. If you have been on the fence about picking up a cab, please keep that in mind!
Some Updates
I have built all the Wire Harnesses for the cabinet as %100 original. Same lenght and same AVG.
All the 90pc of the Wire harnesses are under production in Factory now. I dont have time to make them :P
And i have get all the metals from CNC. Started with Control Panel First.
You can see the some metal parts for Control Panel ;)
What speakers will come with the cab or no speakers installed???
I did a search what I think will work, basically 4" 4ohm full range speakers around 15w rms that are magnetically shielded.
I have a set of these, a bit expensive and not really available in the US, had to order from Germany, I remeber these being basically an almost direct replacement for the oem ones in the Cutes.
https://www.monacor.com/products/components/speaker-technology/hi-fi-full-range-speakers-/sp-10-4s/
I found these on parts express, much lower cost, aa bit better on the frequency range. Seem to also be the right fit.
https://www.parts-express.com/visaton-r10sc-4-4-full-range-speaker-4-ohm--292-602
You guys have something already picked out?
The visatons can be found in Germany for 7,56€ retail price (for sure cheaper if we order hundreds of them)
@edit: Distributor for turkey:
Murat Yalçin
Georg-Strube-Str. 6
28277 Bremen
Germany
Tel:
+49 421 849 8565
Mobil:
+49 173 87 11 673
Fax:
+49 421 847 6989
Email:
[email protected]
Same price on parts express if you order more than 10, so yeah could probably get them a lot cheaper in a bulk order of a couple hundred units.
Does anyone have better speakers in mind at a reasonable price?
so we’ll need some kind of sound amp too I’m guessing? Trying to put a list together and start gathering the stuff. Assuming the repo Marquees floating around will fit also?
You don't need a sound amp.
These come with marquee holders.
