chacal231077
Thank youHere it is.
i don't test the soundI just changed the position of a single jumper because I had a voice problem like mice speaking in acceleratedlol
on the other hand I have a doubtduring the character selection there is the character select in green![]()
watch the video thank you
Somewhat confirmed if this is normal
Thanks again to everyone![]()
Hey guy Thanks youIf this still isn't fixed, I have the correct jumper settings for you.
The only one I notice from your final setup is JP20. It should be on 1-2 instead of 2-3 as you have it in your pictures that were posted on Feb. 9th.
I believe there is a load time on the character select, but I haven't fired my board up in a while so I can't tell you if it is green or not. JP 20 is the only one that I see different from my board.
Brian
