freddiefiasco
Thanks for the offer, much appreciated.I burnt one of these on a Xeltek Superpro 280u, but any burner capable of burning a gal16v8 will do it fine.
Wellon VP390 is a good choice and I think the TOP3000 can do them, not sure about the GQ-4X which is also a popular programmer
Where are you located? If you're in Australia I can burn you one and post it to you if it helps, otherwise someone closer to you might be able to help
You're right. I wonder why that is.I don't think mame has pals. Could be wrong but this should work in any case: http://www.jammarcade.net/files/pals/CPS1-STF29.jed
Sf2 ww for ic location/id STF29
That makes sense.I think they just use code to handle whatever the PALs do. Logic, not memory maybe? Anyway that PAL worked ok?
ah yeah, wasn't sure which it was since I'm not in front of my board - this is that one http://www.jammarcade.net/files/pals/CPS1-C632.jedYou are correct, MAME does sometimes have PAL dumps but they don't for the CPS1. However I don't think that's the right file you linked, fairly sure the PAL on the C board is called a C632, it is also on the jammarcade website though![]()
Is the PAL missing or faulty? If faulty how did you verify that?
If you get stuck, I have a fully working WW board here I can check anything on
Thanks for the offer. I'll hit you up if I need one. I am mainly learning how to resurrect a dead one and I am in the process of troubleshooting the board and narrowed it down to a faulty GAL chip.Well if you're in the US I can burn one
I think the PAL is faulty based on my troubleshooting process:You are correct, MAME does sometimes have PAL dumps but they don't for the CPS1. However I don't think that's the right file you linked, fairly sure the PAL on the C board is called a C632, it is also on the jammarcade website though![]()
I downloaded this one too. It looks like MAME has the C632 file in the set.ah yeah, wasn't sure which it was since I'm not in front of my board - this is that one http://www.jammarcade.net/files/pals/CPS1-C632.jedYou are correct, MAME does sometimes have PAL dumps but they don't for the CPS1. However I don't think that's the right file you linked, fairly sure the PAL on the C board is called a C632, it is also on the jammarcade website though![]()
1. I booted up the game (SF2 WW) and it boots fine.
2. I have a second setup of the same game and I booted this one up and the screen is dark. There are some random flickering maybe every 3 seconds but it's very faint.
3. Since I have a working setup I tried to isolate the issue by narrowing down which board is faulty.
4. I Used the working A board and plugged in the faulty B+C boards.
5. I compared EPROM chips from the faulty set to the working set and SF2-18 + SF2-19 did not match so I removed the Working set from the working B board and popped them in to the faulty B board, same issue.
6. I removed the C board from the working set and plugged it in to the faulty B board and turned it on, display worked.
7. I placed the working set back together to make sure not to confuse myself and it still works.
8. I placed the faulty C board onto the A+B working boards and no display.
9. I took the GAL chip off the working C board and placed it on the faulty C board and powered it up and the display showed.
10. I put the working C board back with the A+B working boards with the original GAL and it works.
11. I placed the assumed faulty GAL chip on the working A+B+C boards and the display was not showing.
Based on the above steps I tried, I narrowed it down to the GAL chip being faulty.
Right now, I'm just stuck with reading the working GAL chip data and comparing this with the data off of the faulty GAL chip to make certain the faulty GAL chip is in fact faulty.
Ah ok, that makes more sense. I was wondering why the values didn't match up to my checks.Unfortunately the original PAL will be protected, also the data in the JED file will have been decrypted and converted for use on a gal16v8 so won't compare to the data on the original PAL.I think the PAL is faulty based on my troubleshooting process:1. I booted up the game (SF2 WW) and it boots fine.You are correct, MAME does sometimes have PAL dumps but they don't for the CPS1. However I don't think that's the right file you linked, fairly sure the PAL on the C board is called a C632, it is also on the jammarcade website though![]()
It sounds like you've pretty well worked out the PAL is bad, so you need to burn and install a replacement. In saying this, I tried to burn the C632 to troubleshoot a board and it didn't work so hopefully you have more luck
Thanks! I'll let you know. I ordered some GAL16V8 chips from China. If they don't work out I'll let you know.@freddiefiasco, I got a Top3000 programmer. If that helps you out any, swing on through.
