rcboosted
I've been doing pretty much that already. I read the EPROM back, and I compared the .a file to the original .a file. The only part that I didn't do is recombine to compare to original. Will do that later today on a new EPROM as a test.that should be correct then.
if you want to confirm you can re-dump after you've burned the ROM, then re-combine and compared against the original file.
