4.02 is needed if you want to use the CF solution without being locked to HAGIWARA cards.Oops. Even better then. Update 2.xx to 4.01. No need to update to 4.02 if you updating a NetDimm. 4.02 is only needed for Dimm's. Do Derick. Let us know how it goes.GD-Rom stands for Gigadisc-Rom, basically because they can allocate 1 Gb of data. They use more "dense" discs which can still be read using regular drives but just slowing down the turning speed. IIRC that means that you need a special customized firmware in your CDROM drive. I've heard some rumours about a soon to release firmware that allows booting from CDR.GD-Rom disc are larger than a CD-R. Not sure what/if any standard can be read on the GD_ROM. but probably not having a blank r/w gd-rom would be an issue.
Is that what you mean?
-at least it's an issue with the DC being GD_ROM
