Random Namco FCA(B) info thread
whatnot
USA
I recently got in a FCA10 and decided to start playing around with it. There's some sparse information online about these and their special manufacture JVS commands.
Anyway, straight to the point. I've modified a JVS emulator I made to dump the internal 64K that it allows you to access. Attached are dumps with dips all off and all on (sans DIP6 which causes the MCU not to power).
I would love someone with a FCA11 and the V290 FCB to get dumps. I'm also interested in dumping the supported JVS commands.
This will allow you to dump the memory: https://github.com/GXTX/YAJVSEmu/tree/dump_70
If you pipe the output with >> you'll have a space delineated map of the memory.
As for the supported commands, if you look at the commit history of that branch you'll see `d43b43de4` which will work to dump the supported commands. Since JVS is a standard we can assume correctly by the status bytes if a command is supported or not (02 being unsupported, any other meaning it's supported and we need more params).
I really would like help with this if anyone is available and willing. The wiring is very easy to set-up, you just need a simple RS485 to USB adapter and a USB cable you're willing to lose.
RE the memory dumps: I'm not really sure what's contained in here - we obviously have copies of the JVS inputs and such but that would only take a few bytes and we have nearly 30KB of /real/ used space. We can see at 0x4000 is a list of strings that the monitor would output, at 0x9000 we see the JVS information - the board name, and what it supports, at 0xFB00 we see the datecode (1998 10/26 12:00:00). Not sure the other stuff, maybe some smarter people than me can check it out. :)
FCA10:
Via dumping my FCA10 I found out a couple of things, one there's a internal "monitor" that you can send commands to `FCA Monitor Ver1.00 by [email protected] 1998.5.20`, no clue how you would attach to this - all of the serial lines on the MCU are used for other things. Another is that each FCA is programmed with a datecode which you can dump by sending JVS command 0x70 0x02. If you send 0x70 0x03 you'll return a bitmask of the dipswitches. In case it comes up, this FCA was pulled from a 500GP for SuperSystem32.
I've programmed what is known now in my JVS emulator: https://github.com/GXTX/YAJVSEmu/commit/286f12247bc1987cfc3fbbf4bce21cc6b5ea3350
well, it's random information so without a place to put it, this thread fits nicely :D
Here's that 60 pin connector pinout on the FGA board from Wangan midnight on the System246, then on the chihiro for the Wangan Midnight Maximum tune and finally FGA 2 from Wangan Midnight Maximum tune 3. Maybe this will help somebody later. I'm going to try to stick a 246 i a WMM3 even though I think the 3xx motor drive board will cause an issue since the 246 is expecting a 2xx.
Came across this thread whilst doing some research, would like to put this info I've collected for others to find.
Main MCUFujitsu MB90F574A
Sub MCUPIC16F84
Chainable:Yes 1
Players:1
Digital:16
Analog:7
Rotary:2
Analog Out:4
The PIC MCU handles the coin slots by monitoring the coin counter lines and not accepting coin inputs if the coin meter is not connected.
  1. Whilst it supports chaining, most of the time the USB-A connector is not populated, nor is the JST-XH 4-pin connector which also acts as the downstream port.
Pinouts​
J101 - I/O Power​
JST-VL 6 Pin
PinFunction
1+5V? 1
2+5V
3GND
4GND
5+12V
6+12VA 2
  1. This pin connects to L1 on the FCA, which is not populated. It supplies voltage to TR6 and TR7 which are also not populated.
  2. This pin is not usually connected, but it was likely designed for connecting to output devices.
J102 - I/O Connections​
JAE-PS 60 Pin Latching - Also JST-RA compatible.
PinRow ARow B
1+5V+5V
2Output 11
3Output 21
4Output 31
5Output 41
6Output 51
7Output 61
8'Analog' Output 1? (PWM)1
9'Analog' Output 2? (PWM)1
10Analog Out 3 (Analog) 2Analog Out 4 (Analog) 2
11Switch 16Switch 15
12Switch 14Switch 13
13Switch 12Switch 11
14Switch 10Switch 9
15Analog 7Analog 6
16Analog 5Analog 4
17Analog 3Analog 2
18Analog 1Test
19Switch 8Switch 7
20Switch 6Switch 5
21ServiceSwitch 4
22Switch 3Switch 2
24Switch 1Coin 1
25Coin 2RS232 RX1 2
26RS232 TX1 2+12V
27Coin Counter 1+12V
28Coin Counter 2+12VA 3
29GNDGND
30GNDGND
  1. This pin is doubled up to the pin in column A for extra current capability.
  2. On most FCA IO boards, the circuitry for this function is not fitted (FCA11/FCA2) - Using these is not possible without modification.
  3. This pin is connected to J101 Pin 6 which is not used by any other function. It's thus variable as to what is actually present.
  4. On FCA11/FCA2, there ware 8 output transistors, however only 6 are reported
J103 - JVS Downstream​
JST-XH 4 Pin Right Angle
This header is not populated on all (any?) PCBs. It is not present on the FCA2/FCA11.
PinFunction
1Sense In
2A
3B
4GND
J104 - JVS Upstream​
JST-XH 5 Pin Right Angle
PinFunction
1Sense In
2A
3B
4GND
4N/C
J105 - Reset In​
JST-NH 2 Pin This header is not populated on all PCBs. It is not present on the FCA2/FCA11.
PinFunction
1Reset
2GND
J106 - Extended I/O Connections/Factory Programming​
JAE-PS 30 Pin - Also JST-RA compatible.
This header seems to be dual purpose, acting as both a factory programming header for both the Fujitsu MCU and the PIC16 chip. It also has extra IO and functions for external I/O interfaces.
PinRow ARow B
1Main MCU MD2Main MCU MD0
2Main MCU RESETSPI CS
3SPI MISO0 1SPI MOSI0 1
4SPI SCK0Main MCU MISO1
5Main MCU MOSI1+5V
6GND+5V
7GND+5V
8GNDPIC MCLR
9PIC DataPIC Clock
10TX1 2RX1 2
11Data 0Data 1
12Data 2Data 3
13Data 4Data 5
14Data 6Data 7
15RS232 RX1 3RS232 TX1 3
  1. Duplicate of the J107 connections.
  2. This seems to be unconnected to the Main MCU or the PIC, thus RS232 is only for extensions.
  3. On most FCA IO boards, the circuitry for this function is not fitted (FCA11/FCA2) - Using these is not possible without modification.
J107 - Serial I/O​
MiniDIN 6 Pin - Sometimes called a PS/2 connector due to the prolific use in IBM PS/2 computers and clones for keyboard and mouse. Is not populated on FCA11/FCA2. It's found on some other Namco I/O boards but it almost never seemed to be actually used for anything.
As viewed from the female connector's face.
_______
6 / o _ o \ 5
4 | o [ ] o | 3
2 \ o o / 1
PinFunction
1N/C
2MOSI
3MISO
4RESET
5CS
6GND
Misc Commands​
Namco I/O boards have some undocumented extended JVS commands that offer more features. These are all prefixed with JVS command 0x70 which is manufacturer specific.
0x01 - Get Firmware Memory​
This command returns bytes from the Main MCU's program memory. Format is:
Payload ByteDescription
00x70
10x01
2Index MSB
3Index LSB
Response from the Main MCU is:
0JVS Status
1JVS Report
2Data
0x02 - Get FW Date​
This command returns the date of when the Main MCU was flashed. Unknown if this is just for version information.
0x03 - Get DIP switches​
This command returns the status of SW1 on the I/O board. Mostly unused
