DJLC
Anyone got a good one to recommend that can handle most modern JVS boards (Naomi/246)? I can't seem to find a good one that does all 3 outputs and has a decent amperage.
Thanks!
Thanks!
Where did you get it? I'm need one also.
Mouser or Digikey would be the normal go to for these.Where did you get it? I'm need one also.
DigiKeyWhere did you get it? I'm need one also.
do you have any picture about your installation?
I have this power supply installed in a Mini Cute and have it wired for JAMMA and JVS.do you have any picture about your installation?
The in-line fuse holders I have on the JVS harness have 7.5A fuses on the 3.3V and 5V lines and I haven’t had any issues. The PSU is rated for 10A on both of those lines. The only JVS board I have and have tested is NAOMI.is it sufficient for Naomo mobo or chihiro, 400 w required.
The harness to the left goes to JAMMA boards and the harness to the right goes to my NAOMI.
I added an AMP connector to the JVS power harness so that I can easily disconnect a NAOMI board when not installed.
Here is the JVS power harness. I added in-line fuses as extra protection.
No cuttingreally curious how you wired up the additional outlets. Did you cut a hole in your mini cute?
No cutting
There’s an AC line from the PSU that goes up to the monitor above. I inserted an AC adapter with USB outlets since the AC line terminates into female plug. This is so that I can run heat extractor fans. More info on that project here.
