Trol
and its running Thunderhoop?
Could you take a picture of the Board?
It's running fine as TH - not tried the conversion yet as it's using 27C408's and I'm waiting for some more 27C040's to turn up from China.Is it actually working though? You seemed to imply further up that there were issues
Take note of the jumper configuration too.I didn't think TH was on a /2 PCB - I'll dump the roms and check them against MAME.
I’m pretty sure I could program a 20v8 with my top3000 but it was such an inconsistent event that I bought a xeltek 610p.Could be a unknown dump, so would be cool to know, and if it's a different set, get it into MAME as well.
Trol had issues with his 3000 so he sent some GALs to me, i got a little further in programming the 16V8 at least but the 20v8 always errors on verify, L320 and up fail on verify![]()
If anyone has the top3000 working with GAL20V8 please chime in![]()
And yes i've noticed you can use / edit the device3000.lst file and change/add devices vpp, vcc and algo's used, but i still could not get it to write the 20v8 even with external power supply.
I use a TOP3000 everyday and do program a lot of GALs with it no issue. The first batches of all the kits I've made were programmed with it.Could be a unknown dump, so would be cool to know, and if it's a different set, get it into MAME as well.
What's a 27C408? I'm not familiar with thatIt's running fine as TH - not tried the conversion yet as it's using 27C408's and I'm waiting for some more 27C040's to turn up from China.Is it actually working though? You seemed to imply further up that there were issues
Yes, the component is a Darlington array for coin counters/lockouts hence it can be the cause of the color issue.The problem coud be due to a missing VIDEO GROUND connection, sometimes Gaelco forgot to tie the COMMON GROUND to it.So, try to wire pin 14 parts side of the JAMMA edge connector to pin 1-2 or 27-28.It looks to be connected to the coin counters and coin lockouts. I doubt if its needed.
