Removing Monitor Sega Aero Table
SailorLodestar
Glendale California
Does anyone know any resources or have any tips on removing the monitor from a Sega Aero Table?
I've finally tracked down a replacement for my burnt-out monitor but I've never removed the old one before so I'm not sure where to start.
How do I even reach in there to discharge it and unplug any wires? The chassis is at a weird angle with the front service door.
Thank you for any help you can provide.
I recall it was pretty simple, my monitor came out many times. You certainly do not to discharge it before removing.
1. Remove the 4 large hex nuts holding it in place.
2. Disconnect power, degaussing etc.
3. Disconnect RGB-sync cable small connector
Lift straight up, the monitor is in a metal frame so pretty simple to lift, just be careful everything is unplugged, may be easier to drop out the control panel to access the cables.
