Repair Log: CPS1 No Sound
I bought 2 new ls374 from a trusted seller, but there's no sound at all. Previously, there was a looping sound almost every time I turned it on, but now it only happens once out of 15 times. What else should I change, 68000?
My experience with the chinese cps1 is if it seems like a knock off part it is.
The only way I fixed mine was a full proper recap with correct audio amp and swapping the knock off parts.
Plus reburning the eproms.
I know they seem like a deal but by the time I corrected all that it wasn't.
Samsies, I got mine working by replacing the SRAM, but I didn’t trust any of the cheap parts, so I just transplanted everything else from a donor with a failed A custom.
That's what I plan to do. I also have a bootleg audio hack that works and a donor A PCB with a bad custom. I'm going to move everything over in the audio section and remove the janky audio. I plan to make a vid of this (when I get to it, I have a ton of vids and repairs in queue).
Del
Seems to have solved the problem -68000 transmits to the z80 what to play and at what volume on 2 eight-bit buses. From PAL IOA1, the signals go to the 5B LS32 and then to the 10J, 11J LS374. Using an oscilloscope, I checked that both signals were coming to the LS32, but only the second signal was outputting, and the first output was silent. I transferred the LS32 from the working board, and everything started working. I don't know how long it will last, but judging by the marking, the faulty LS32 was not original. I'll test it to see if the board kills them over time.
My SFII: TWW boardset had no sounds at all when I turned it on earlier today (I've had it for 19 years and had never had even the slightest hint of sound issues). By doing some board swapping I narrowed it down to the A-board. The first thing I tried (after reseating the socketed chips didn't help) actually fixed it, surprisingly: I re-soldered the volume pot's three legs (VR1).
Apparently one or more of the volume pot's solder joints have always been marginal, because for as long as I've owned it, I've always had the volume pot turned all the way up just to get a good volume, and after re-soldering its legs today, I had to turn it down quite a bit to get same volume it had before. It was way too loud with it turned all the way up.
