Takosuke
Alright, let’s take a look at the Cowboys of Moo Mesa board I just got.
No video, no sound.
A quick inspection of the board shows a few things:
- The edge connector has a missing pad on the solder side, at the emplacement P where the Video Sync should be
- there is a blob of solder on the pinhole right beneath C and D where the 5V is (not sure if this one matters?)
- The sound module 054864 seems to be out, probably the cap leaking as usual for those board
- one of the legs of the Konami 054157 IC seems to be bent inside, but a quick continuity check does not show that it’s broken or shorting with anything (seems safe for now)
My first step will be to repair the edge connector.
Any advice on connecting the metal pad to the super tiny trace? Usually it’s easy to solder on a bigger trace but that’s the first time I will have to do it on something so small
No video, no sound.
