Replacement Ringedge 2 power supply
Those are pretty specific, if you have someone close that can do the job, the best is to try to repair it. It's electical job, so many skilled people could fix it, if not the best IMO is to get one of those cheap faulty units and take the PSU and discard the rest as these are pretty specific. If I'm not mistaken the exact model is: Delta Electronics EDPS-250AB A
It's mostly just a flex ATX power supply with a funny connector for the SSD (you can use a regular SATA power cable instead) and the 14 pin mini-fit jr connector with the Lindbergh pinout for the DC out on the rear. The form factor is a bit taller than flex ATX, so you might have to get a little creative mounting it.
If you're not using the DC out on the rear of the case, you can just throw in a regular flex ATX and be done with it.
If you need he DC out, you'll need to wire up an adapter.
