ArcadeMachinist
I had this board working about a year ago.
Tried to run it yesterday and it would not boot.
MAME for ref: https://github.com/mamedev/mame/blob/master/src/mame/sega/segaybd.cpp
I looks like First MC68k CPU IC12 (315-5314 on MAME ascii art schematic), is stuck in a boot loop, 2 other MC68ks are idle (not booting).
CPU resets about 3 times per sec.
* RST pin jumping up/down 3 times per sec (50ms low/300ms high)
* 12.5 Mhz clock signal is ok
* Activity on address and data buses.
* Voltage levels are ok (4.89V should be ok)
* CPU2 & CPU3 RST stays low (I guess CPU1 would init that, farther during the boot)
* there is a clean video sync signal (video is a separate PCB under the main one)
I suppose some UV erasable roms went bad? sram?
Any reccomendations on approach to diagnostics?
There is just 1 electrolytic cap around, there is clean VCC around it, so it should be fine.
