GAROU has a patched beta version running, it doesn't crash when you make a super punch from one of the fighters. davidmorom posted the patch a few pages ago.
The second cartridge also worked in the end -I didn't understand what was going on, I soldered everything that was, but in my opinion, soldering Srom helped in the end from crosshatch. But there are vertical artifacts in the image that change when you touch the Crom pins - contact disappears somewhere, I'll look for it later while I make the last third cartridge. All 3 F0095H0S that came from Aliexpress turned out to be serviceable, but I'm working with the firmware from ikari and with a mod to lower the voltage to 3 volts.
