RingEdge 2 - Error 0082 "Game Program Access Failed" with multi ssd [resolved]
aoiddr
Georgia, USA
[UPDATE: The issue was the PNY SSD I had in the system. It was basically going bad. It was able to be unlocked, and then was never able to be locked again. So it basically bricked itself.]
I have a RingEdge 2 running the Multi (PNY SSD) that is giving me Error 0082 "Game Program Access Failed" when trying to boot.
Does anyone have an idea what might be causing this and how to correct it?
Additional Context:
-I bought the RingEdge 2 with Multi installed off a member here in early 2021 and it was working at the time of shipment.
-I never got around to testing it, so this is the first time hooking up in a cab (Sega New Net City) since buying it.
-I tested it with an HDMI monitor and actually got a BSOD (attachment below). I didn't have an i/o board hooked to it at the time, though.
-I set the right dip switches [DIP 5 ON (480p), rest OFF] and hooked it up to the Net City, but the system thows the Error 0082 that it currently showing.
Here are some pictures of the info from within the service menu, in case this helps.
