mourix
Developments and monitor frustrations..
Still trying to get 15KHz working on the Wei Ya monitor. Thought I had it when I found out the daughterboard relay measured 5 ohms terminal resistance. Put in a new relay but no cigar..
As for the developments. I happened to own a Japanese VA1 Dreamcast, and the Atomiswave has a dual Japanese power outlet on the inside. Are you thinking what I'm thinking?...
One Aliexpress GDEMU, battery holder and PTC fuse later:
To get it going in the cab, I am designing some some custom open source PCB's though.
First off, this great project turns any raspberry Pico into a Dreamcast controller. Annoyingly enough it seems no one made open source PCBs for it as his license is very kind/permissive. Let's change that:
Secondly, the stereo amp for Egret 3 / Atomiswave is unobtainium at this point. Lets make a converter PCB for an Aliexpress TPA3110 module with the same power output as the original:
