screw for seimitsu
nonosto
FRANCE
Hello
What's screw I need for Seimitsu LS-32-01-SS to scewed it on the panel? exact ref prefered please.
THX
you don't necessarily use screws. it depends on your panel I've got some panels that have M3 or M4 studs so you'd need an appropriately sized nut, I have another panel that uses M3.5 screws.
it depends entirely on your panel.
this is for this plate (HRAP PS2):
So could you advise me about a seimisysu stick for this plate:
thx
As a pure guess that looks like it's probably an M4
Really you should be asking people who are familiar with the HRAP. As someone who only deals with arcade cabs I have no idea.
Apologies for the necrobump, but I was wondering if anyone had experienced this before.
Am trying to remove the stock Seimitsu stick from my HRAP 3 Seimitsu Edition but the darn screws are stuck to the mounting plate.
Have tried Phillip heads as well as JIS screwdrivers as well but it just won't budge, any advice for this situation :unsure:
Thanks
Give it a hard knock with a small hammer or similar object. That should free up any stuck threads, or loosen up any Loctite or similar product.
And by hard knock, I mean a swift tap, you don't want to bend the thing, you want to surprise it so hard it gives up its grip.
Will give this a go, from the back side or from the front of the panel?
I thought about trying an impact screw driver as well but the pcb assembly of the stick will get in the way i think
Just tap the screwdriver into the head of the screw.
