diosleon
Hello! I just got a model 3 with Virtua Fighter 3tb. It didn't came with any cables. Do you know where can I find some?
YAJ. Sega Model 3 is super easy to find there. I got one for like $65+ shippingHello! I just got a model 3 with Virtua Fighter 3tb. It didn't came with any cables. Do you know where can I find some?
Would this be able to connect the board to a jamma cab?YAJ. Sega Model 3 is super easy to find there. I got one for like $65+ shipping
If not paging @Lemony Vengeance may be able to help.
What cab? And you'd need a 31khz monitor to display Virtua Fighter 3. Vga input onlyWould this be able to connect the board to a jamma cab?
I think you're right, I guess I miss-spoke because I hooked up my VF3 to my Tri Sync Blast via VGANot quite, VF3 like most Model 3 games runs at 24KHz which is around 512x350, won't work on most VGA monitors. I found this out the hard way when I was testing my Model 3 board and thought it was going to output 31K/VGA, but nope, I didn't get any signal on any of my displays. Plugged it into my capture card (which supports 24KHz) and immediately got a picture.
Never assume that HD15/DE15 automatically means VGA output, you may be in for a bad time, depending on what you're doing.
An Astro CityWhat cab? And you'd need a 31khz monitor to display Virtua Fighter 3. Vga input only
