FS Sega Naomi Net Dimm & Regular Dimm
St4rgalaqtic
Pittsburgh,PA
After getting my Naomi 2 up and running I’m continuing to clear out my extras. Time to stop hoarding stuff.
Naomi Net Dimm lan port only model fully tested 256mb ram. 4.02 and zero key included - $260 shipped in the states
Sega Naomi Dimm super old firmware 1. Works but will need to be updated which for this older model will require soldering and flashing. I know a few on this forum offer the service. Also looks like its Fairchild chip was replaced sometime ago. It’s ugly but it works, this is not my work. $125 shipped in the states
Broken Dimm lot SOLD 2 x dimm 1 x net Dimm
1 Dimm has an error 22 and some obvious worked done on it, not by me. Second Dimm smoked when I plugged it in, it has a white residue on the bottom of the board. I opened the dimm and nothing sticks out as an Issue. I cannot tell where the smoke came from. Unplugged it asap. Third is the netdimm, it’s in rough shape, one of the connectors on the bottom is damaged and the daughter board has some rust and corrosion. I remember soaking it in cleaning vinegar when I got it. Bright side is the daughter board even though in rough shape works perfectly. $200 for the lot shipped in the states.
