FS Sega ST-V, Sega 16B and Sega C2 (also Irem M72) multicart game selector with LCD screen
Not publicly, but I have sent instructions privately to everyone who wanted to have S16B selector. It's very simple to install, no need for soldering. Just get the wires in needed length (varies how you want to locate the selector), plug and use. Sega C2 is almost same, but game PCB needs pins added = small amount of easy soldering. Irem M72 is easy too. Sega ST-V is most complicated to install.
Australia: should be 17-46 Euro, depending without or with tracking. If you want to order, PM and I'll check better.
So this LCD selector will work with the Irem M72 as well?
Edit: It does and OP is nice guy all around.
Excellent! Thank you very much :D
I am ordering the S16B multi next week, so I will send a message shortly 🤘
@stt1 works great! thank you.
Will they only work on the Apoc C2 multi, or also the AJE one?
A very good question, so far I can only say that it works with the Apoc C2 multi. With AJE... it should, if the selection logic, voltages and connectors are similar. But I have no way to test as I don't own AJE version (and actually never seen one).
