FS Sega System 1 aka System 8 Multi (Gadget Freak)
Monstermug
London, UK
He has a limited number of Sega System 1 left with no current plans for a re-run so grab them while you can.
£350 each plus shipping at cost.
4 sold
2 on hold
Remaining units:
2 x pio
1 x Ppi
1 x regulas
Manual here
https://www.dropbox.com/scl/fi/zdse...ulti.pdf?rlkey=t920y76ldqqizb89np9yxoar8&dl=0
Ignore the rom burning etc. It comes ready made plug and play.
They will work on standard Sega pcbs as well as Midway and Regulas type boards as well as techfri boards providing there are no daughterboards preventing the installation of it.
View: https://youtu.be/yqEwpph5v4A?si=naRe6oYGd9bQB5SD
Ignore the power cycles to select different games, i did not read the manual which says you can do it with key presses.
Saves high scores for each game as well as a lot of cool other features which you will find out about if you read the manual unlike me. There are pics which was what i used to install.
They are £350 each plus postage at cost (which shouldnt be much) they are plug and play unlike other multis. Shipping from UK.
Attached is the manual. You will be paying him direct and if you have ever dealt with him before, his after sales support is next to none. Once he even fix the pcb for someone when they couldnt get the multi to work which i thought was very nice of him.
Also comIng SOON to a stall near you is the multi that allows you to play super locamotive on a choplifter pcb... stay tuned. Pre-order is interest will be noted and knowing Gadgetfreak, he probably print a dozen pcbs just to make one and move on to his next project. Will be similarly priced i should expect.
Just read the manual! Ignore the rom burning. It comes complete with roms already burnt just plug and play.
