CoolFox
California
Had a few requests to make some more of these. I have enough parts for 3. This is a converted board from a different game. I installed Tetris Giant on it and made a Jamma adapter + plugs for a regular Sun power supply (Naomi power supply). Has stereo audio and runs in 31 khz. Looking for $350 + ship.
If I knew there was a way to get or build the controllers for this, I would jump on this instantly
Well this will play on a regular jamma cabinet as normal Tetris. I actually brought it to CAX a few years ago and was quite popular.
What controllers would you want to use? Joystick and buttons are standardized imo, but I am assuming you mean a console controller?
Should be easy enough to route a PCB for that.
Yes, or if you have a supergun you might have neo-geo/genesis controller options. Isn't it JVSish as well? So you could probably use one of those newer JVS emulator things with a USB gamepad? Lastly You could literally hack a game controller pcb to the joystick/button switches in the control panel. I've done this before but in the opposite way. Normally I would tie the arcade controls into the game controller pcb and plug it into the console... In this case I would tap into the switches on the game controller and tie them to the arcade input signal lines.
All of that seems like quite a bit of work when you could just play it on a regular JAMMA cab?
I was referring to building a legit controller setup like the huge ones you see people plaything this game with. Anyone know or those parts would be possible to get?
Anyone may have the scanned PDF document of Tetris Giant? I would like to see how the original giant joystick with force feedback work. Perhaps it maybe possible to DIY the giant joystick
