zetsurin
HI all,
This is my first foray into PCBs and using KiCad, but I have made up a PCB designed to fit inside the NVS 4000 enclosure allowing the aging power supply to be replaced by a new SFX power supply, while retaining the original appearance. I was driven to this after recapping a PSU only to find out it's definitely not the caps etc. It's currently a work in progress and it's very much a DIY project since the 90 degree AMP UP connectors themselves need to be de-soldered from the original and resoldered. I've stuck with the original types of connectors that were originally used in these arcades, perhaps for a bit of authenticity but they are still fairly easy to track down for now.
Basically:
- Right angle ATX header (later changed to straight header as it's a tight squeeze)
- Replace rear fan with 80x80x10mm fan to further save space.
- 3 pin 90 degree AMP connector for power
- 2 pin right angle JST XH for fan header
- Straight 7 pin JST HX for test/service/jamma audio.
- Optionally: A negatron.
- 5mm 12V red LED
- approx 300 Ohm or so resistor if one isn't built into the LED.
I can grab all the parts and links to digikey shortly.
Not sure if it's useful to anyone as it's a pretty niche situation, but in case it's useful I thought I would share what I made so far. I had a first run made and it all seemed to measure up fine in place in the NVS4000, and have just revised it to optionally take a Negatron to add -5V.
Since I am really learning about PCB layout, any feedback would be appreciated. And if anyone is thinking of getting boards made, please wait until I get the next batch back to test first.
Basically:
- 5mm 12V red LED
