I'd just resolder it and see how it goes.
I've found that with physical damage to transistors generally the legs will snap off before you damage it internally.
capacitors and crystals will often be damaged internally before the solder breaks.
you can usually tell if the leg feels lose in the component body then replace it, if it's still mounted solid, like new, then it's probably fine.
