Small & Simple 3D print job needed.
streetfighterken
Sioux Falls, SD
I need this panel done for my Crazy Taxi sit down. It holds the 24mm Start and View buttons. I already have it in EPS format. Thanks.
How big is the plate you need? With a png file it's hard to guess real size.
I could probably 3d print that for you or maybe cut it out of some material using a laser.
okay, that's not too bad. If you're interested I could 3d print that in whatever color you like in ABS (Lego) plastic. Else if this is going to be a visible part I could laser cut it out of 1/8" sheet of acrylic. How thick does it need to be?
I would think this is a much better job for a laser cutter. I believe the original part is sheet-metal is it not?
Original part is 1/16 stainless steel.
1/8 acrylic is fine, but I'd want it to be black.
Saw your site -- I may have you cut some marquee holders for my Astro Cities as well. Exact repro not necessary, just simple panels with marquee sandwiched between. I'll hit you up in a couple months with measurements. Get it all done in one shot. Thanks.
