SMD cap ID
rewrite
Multi Boyz Litigator
Immortal
Multi Boyz
SoCal
Been putting this off a long time as I hate installing these. I'm not even sure the proper term as I've seen them called half a dozen things.
Bought a cap kit for my Compact XVI and nothing is labeled.
The manufacturer labels on top of these three sets of caps are all Greek to me.
One of these should be 0.47uf, I know that much. The other two I'm not sure about.
Any help is appreciated.
https://imgur.com/a/qydKcfi
It should be 47uF or 470uF, I can't read well the digits from your picture (if 'C' or '0')
Anyway, this is the complete capacitors chart of the X68000 CompactXVI :
Mainboard:
C1SUB 50v 0.47uf
c1 50v 1uf
c2 25v 4.7uf
c3 6.3v 470uf
c4 6.3v 470uf
c5 6.3v 470uf
c6 6.3v 100uf
c7 6.3v 47uf
c8 50v 0.47uf
c9 50v 0.47uf
c10 50v 0.47uf
c11 25v 4.7uf
c15 6.3v 47uf
c16 6.3v 470uf
c18 6.3v 100uf
c19 6.3v 100uf
c20 6.3v 100uf
c21 6.3v 100uf
c22 6.3v 100uf
c23 6.3v 47uf
c24 6.3v 47uf
c25 50v 1uf
c26 6.3v 100uf
c27 16v 10uf
c28 6.3v 100uf
c29 25v 4.7uf
c30 6.3v 470uf
c31 25v 4.7uf
c33 50v 0.47uf
c34 16v 100uf
c35 16v 100uf
C36 6.3v 100uf
c37 6.3v 100uf
c39 25v 4.7uf
c40 25v 4.7uf
c41 25v 4.7uf
c42 6.3v 100uf
c43 6.3v 22uf
c44 6.3v 100uf
c45 16v 100uf
c46 6.3v 100uf
c47 6.3v 100uf
c48 50v 1uf
c49 6.3v 100uf
c90 6.3v 47uf
c348 50v 1uf
c351 50v 1uf
Controller port board:
c501 6.3V 100uf
Expansion board:
c701 6.3v 47uf
c702 16v 47uf
c703 16v 47uf
Thanks @brizzo. That means I got sent the wrong number of a couple of these :/
That's the chart I'm using.
Looks like console5 must have sent me incorrect amounts of these three if they're as you guys guessed... Again.
Try to measure them with a capacity meter.
I'll try that. Bought one but have never used it yet. Ha.
Also, C32 is missing off of that list unfortunately. The cap right behind the four ribbon cables.
Edit: meter does not go down to 0.47 :/
@brizzo Spot on.
I uh, forgot I had this little meter until @caius mentioned it. :/
Caps figured out! Though the cap list is still missing C32 so I'll have to figure that out.
