XeD
Does anyone know the eeprom equivalent so I can write a copy to the cart?
What do you mean by EEPROM equivalent ?Does anyone know the eeprom equivalent so I can write a copy to the cart?
Pop open your cart and take a few hi-res pictures and we will seeWhat ic do I need to update/convert a MvC2 cart to this new code
@TopTierArcade very nice video. I think this deserves it's own thread.Sega Blast City Arcade - Cabinet Restore - Part 1 - Adding Games to the Naomi Pi [HD]
Hey everyone,
In this tech video, I do a step by step walk through on the Sega Blast City Arcade adding games to the Naomi Pi. I add the Atomiswave library to add to the existing Naomi library already loaded in the Naomi Pi. This also works for Naomi games, including the new Marvel vs Capcom 2 Unlocked all characters, which I added and working perfectly!!!!
All this and much more in this video...
Hope this helps out. You guys/this forum gave me the information and confidence to figure this out and find the ROMS. Thanks again
Very nice of you to say and recommend. I also put it under the Naomi/Atomiswave section@TopTierArcade very nice video. I think this deserves it's own thread.Sega Blast City Arcade - Cabinet Restore - Part 1 - Adding Games to the Naomi Pi [HD]
Hey everyone,
My absolute pleasure! Happy it all worked out and you are enjoying the games.Just wanted to say thanks again! I had to load a different game and then the hacked MvC2 so that everything unlocked (probably because MvC2 was the last game loaded)
I got a 'File not found'.Here's a pre-made IC22.bin if you want to program this for your real cart.
https://nofile.io/f/7sKbA6jyZom/Unlocked+IC22.Bin
Tested on 3 different US NAOMI's and a Japanese NAOMI2.; this worked beautifully! Now my OG MvC2 cart has all the characters unlocked without ever having punch in the codes. Just make sure you wipe the NAOMI's settings if the last cart plugged into your NAOMI was MvC2, otherwise it will load the settings saved to RAM. Pop in another cart to do this or do it from the TEST menu.Here's a pre-made IC22.bin if you want to program this for your real cart.
https://mega.nz/#!M0wXhaAC!69OPhH6tZh3o3AvHH83NzrDsyzVpvDdepnO5LzWo1DY
You don't have to buy new EPROM's, you can erase and rewrite the one that is in there. Just pop it out from its DIP package. You'll have to unscrew two screws from the PCB to remove the shell to do this. No biggie though.For some reason I tbought it was a different eeprom. I can burn those with my 2 current programmers. Time to buy some eeproms
