digitron
Boxed Namco Arcade stick originally for the PS1. I carefully modded this, no cuts or drilling were made to the body whatsoever. The JLF joystick mod is completely reversible and includes the original joystick body and switches so you can revert it back if you want. I also added Cherry D44X micro-switches and wiring harness.
I soldered in new Seimitsu PS-14-G buttons and installed the GP2040 breakout PCB (designed by RGB).
Barely used, just pretty much built it and it sat in my room since.
This is plug and plug, the micro-USB cable is a little short but can be easily swapped. Note - there is a small tear in the box over where the joystick stands.
Let me know if you have any questions.
https://imgur.com/a/namco-CL7Wgiv
$120 shipped F&F USA only
