YaYaLanD
Hello !
i bought in october 2019, 2 9“ sony 9042QM PVM.
One was always black and white. I managed to solve the problem after a deep cleaning and some soldering reflow here and there where the solders were looking suspicious.
the other one has a screwed image on the left and right side with some king of wiggling on the sides.
The wiggling is more and more visible if i turn brightness all the way up. And tends to disappear but not completely, when the brightness is very low.
please take a look at the picture.
what i tried so far.
i swapped the B board and the D board from the working unit to the non working one.
nothing had changed.
please refer to the attached link for the service manual
https://www.manualslib.com/download/1282003/Sony-Trinitron-Pvm-8042q.html
as per the manual, D board deals with
H oscillation freq, screen phase, H/V BLK, H/V deflection, H/V delay, while B bord deals with primary colors matrix, burst gate width, VXO, NTSC/PAL/SECAM, chroma pulse.
When i swapped the boards, the working unit had still its beautiful Picture.
now i start thinking that the P board which contains the EHT has a problem. Maybe the EHT itself ?
do you guys can give me a path to follow ?
Can i swap P board to test ? Isn’t it dangerous for the tube ?
What should i do next ?
i didn’t touch any Of the potentiometers.
thanks for any comment or any help.
