Igorm
I wanted to see if I can find what is the issue with my spiderman pcb, where the green color dominates over the white, so I found the pinout for the video mixer(DAC) ic60, digital pins show steady pulsing for all bits for rgb, but I see very low voltage on the analog out for red. More than 50% less than green and blue. Connection from jamma rgb pins to the analog output pins looks fine. Not sure what else to check. It seems the ic60 has some internal issue and maybe I should replace it?
Cleaned the pins, other games work fine, I use makstrike v3 supergun to a small tv. The built in crt test with the bars shows only green, based on the checks i did, it looks like red is underperforming,even though i can see blue and red during gsmeplay
Tried uploading the pictures from the board and the game running, but files are too big, will add them later.
Thanks
Thanks
