Street Fighter Alpha 3 Challenger's Edition - CPS2 Multi
cmoliveira
Ontario, Canada
Hey All,
Arcade Atavism released the patches for Street Fighter Alpha 3 Challenger's Edition here:
https://github.com/originalgrego/sfa3ce
I tried to apply them using Floating IPS to each corresponding numbered flash file from the original sfa3u and also sfz3j folder but couldn't get it to boot up. Has anyone else been able to get this running on the CPS2 multi?
I got it to work after lots of trial and error. After talking with Grego2d a bit, I have reason to believe that the darksoft IPS files are not working. He's looking to fix it.
In the meantime, see below what I did to get it working - I walked through all steps in getting the unencrypted file patched for MAME, then got those files working for Darksoft. Special thanks to @rtw for his Multi Generator to assist.
## How to patch your Street Fighter Alpha 3 ROM
MAME UNENCRYPTED ROM
1 - Obtain the original MAME ROM set for the USA version of Street Fighter Alpha 3 (980904) (sfa3u.zip) and extract it to an empty folder.
2 - Download the decrypted version of SFA3 (980904) from https://cps2.avalaunch.net/ (sfa3udi.zip) and copy the ROMs contained over the original ROM files.
3 - Delete the files "sz3ud.03c" and "sz3ud.04c" and then rename "sz3udi.03c" to "sz3ud.03c" and rename "sz3udi.04c" to "sz3ud.04c"
4 - Apply the SFA3CE IPS patches from the "graphics" and "unencrypted" folders to the ROMs that match their file names. For Alpha 3 branding, use the IPS files in the "sfa3ce" folder. For Zero 3 branding, use the IPS files in the "sfz3ce" folder.
5 - Zip the contents of your patched folder and rename it to "sfa3ud.zip"
6 - Put it in your MAME ROM directory. You might want to keep a separate installation of MAME for hacks so that they won't contaminate a clean ROM set.
7 - Run the game from the command line in your MAME folder, or create a .bat file in your MAME folder that contains the text "mame64 sfa3ud" and simply run that.
8 - Enjoy!
CONVERTING UNENCRYPTED MAME ROM into a DARKSOFT ROM (requires additional fan-made software)
1 - Ensure you have followed steps 1-7 of patching your MAME Unencrypted ROM (see above).
2 - Unzip your "sfa3ud.zip" - labeled "sfa3ud" and put it into your MAME ROM Directory.
3 - Add phoenix.key into your "sfa3ud" folder. (Can be found with alternative versions of sfa3ud.zip online).
4 - Add "Qsound_hle.zip" that icludes dl-1425.bin into your MAME ROM Directory. Unzip the file so it is an open folder.
5 - Download the CPS2-Multi ROM generator from author rtw, as posted on Arcade Projects (https://www.arcade-projects.com/threads/cps2-multi-romset-generator.9425/)
6 - Add the cps262.exe file to the same directory as your MAME binary.
7 - From the MAME binary directory, enter Windows Terminal.
8 - At the Windows Terminal, enter "cps262.exe sfa3ud"
9 - You will see the following compile:
C:\Users\username\Documents\MAME>cps264.exe sfa3ud​
sz3ud.03c WRONG CHECKSUMS:​
EXPECTED: CRC(6db8add7) SHA1(f6dc8ed330254acab16e42a8e729bca7713c8dc1)​
FOUND: CRC(0198ac84) SHA1(8226d7b606f567aea019fa3126a31987b5b774b8)
sz3ud.04c WRONG CHECKSUMS:​
EXPECTED: CRC(d9c65a26) SHA1(8293ef112eaa534b58a3b56721af5d2f53fd1576)​
FOUND: CRC(38af80aa) SHA1(4c35616d04ea109d25362dba3e5baa243b7539ad)​
sz3.09c WRONG CHECKSUMS:​
EXPECTED: CRC(b29e5199) SHA1(c6c215eb5aa37f678a9cafcbd8620969fb5ca12f)​
FOUND: CRC(8353dae0) SHA1(b6fd70d95ed5180e4fa953b30f3668b64a24343a)​
sz3.13m WRONG CHECKSUMS:​
EXPECTED: CRC(0f7a60d9) SHA1(c69e0ee22537312909dacc86d2e4be319d54e426)​
FOUND: CRC(d941f463) SHA1(fae09d5d29ef3d9650440e589ac574c98f20b899)​
sz3.15m WRONG CHECKSUMS:​
EXPECTED: CRC(8e933741) SHA1(f4ac4bfe830dc7df9fe4f680e4e0c053e7cbd8fe)​
FOUND: CRC(d25f4fbf) SHA1(dee478f694c11f2ab17821f471ed2ed270d5d113)​
sz3.17m WRONG CHECKSUMS:​
EXPECTED: CRC(d6e98147) SHA1(37f331fbb1284db446faecade6f484f58c0e1b2a)​
FOUND: CRC(5c210d31) SHA1(27e6f75640f1a8b06e23b820fdfcb22728d517cc)​
sz3.19m WRONG CHECKSUMS:​
EXPECTED: CRC(f31a728a) SHA1(f14136564648f006c1b74afda78349f260524b5f)​
FOUND: CRC(a0b6f359) SHA1(4e053f29fda3211d7356d3af8005ad195b199c2f)​
WARNING: the machine might not run correctly.​
CPS2-Multi ROMset generator (Apr 5 2021/23:11:01) (0230)​
coding : rtw​
directory: .\cps2\games\sfa3ud\​
writing file: flash.01​
writing file: flash.02​
writing file: flash.03​
writing file: flash.04​
writing file: flash.05​
writing file: flash.07​
writing file: flash.09​
writing file: flash.11​
writing file: flash.06​
writing file: flash.08​
writing file: flash.10​
writing file: flash.12​
writing file: key​
writing file: name​
8 - You should now have a folder in your MAME directory called "cps2" with another folder in it labeled "sfa3ud"
9 - You are now going to copy the NAME file from the sfa3ce-main > ips > darksoft folder and place it in your new "sfa3ud" folder found under "cps2." You will be overwriting over the one that was already there.
10 - Rename the "sfa3ud" to whatever you would like. Copy the directory and all other games to a freshly formatted SD card's /games directory for your darksoft modded CPS2-kit.
11 - Enjoy!
A few things I've observed about these hacks so far. I have alerted the developer - he cited he is working on a fix.
  • SFZ3CE (The Zero 3 branded version) always uses the censored version of some stages (R.Mika, E.Honda). It is supposed to function that if you have Voice Type turned to OFF in Dipswitch settings, it disables japanese language in the sound and has modified stages, but right now no matter what, you always get the censored stages. SFA3CE (Alpha 3 branding) is unaffected and works fine.
  • Akuma's teleport shadows display incorrect colors. 2nd shadow moving forward displays a character color that fits the ism, as opposed to what you selected.
I haven't gotten much traction in the other thread but do you know how I can get this Zero3 training rom running on the dark soft? https://github.com/0xZERO3/ZERO3TE
I managed to load it but it doesn't seem to be working properly. The commands are not working. Any advice would be greatly appreciated!
