Street Fighter Alpha 3 MAX (Arcade backport)
strygo
Snohomish, WA
Street Fighter Zero 3 Double Upper (Japan).
Street Fighter Alpha 3 MAX (USA).
Download and instructions at arcadepatches.com
Current version: rc1 (November 28, 2026) · USA and Japan​
Street Fighter Alpha 3 MAX added Eagle, Maki, Yun and Ingrid to Alpha 3 on the PSP, where Japan knew it as Street Fighter Zero 3 Double Upper. It never came to the arcade.
This backport brings MAX to CPS-2 as an arcade game, built on Street Fighter Alpha 3 Upper (CPS-2).
What's in it​
  • Eagle, Maki, Yun and Ingrid join the playable roster, with their own moves, win quotes, story scenes and arcade endings.
  • Their own cells on the select screen, next to every Upper fighter, and appearances in the attract mode.
  • Everything in Street Fighter Alpha 3 Upper (CPS-2): Guile, Fei Long, Dee Jay, T. Hawk, Evil Ryu and Shin Akuma, with their stages, endings, voices and QSound music.
  • Two builds: USA as Street Fighter Alpha 3 MAX in English, and Japan as Street Fighter Zero 3 Double Upper, with Japanese text and names.
  • Arcade mode and its two-player challenge. World Tour and the other console modes are not included.
Eagle, Maki, Yun and Ingrid join the Upper roster.
Ingrid's super against Zangief.
Eagle against Rose.​
Getting it running​
  • On MiSTer, it needs the included CPS+ core and 128 MB SDRAM. On a computer, it needs an HBMAME or FBNeo build that includes the MAX and Double Upper sets.
  • You need your own arcade romsets in canonical MAME format: sfa3, sfa3u, sfz3j and qsound.
  • You also need the same disc images as Upper: the USA Street Fighter Alpha Anthology and Japanese Street Fighter Zero: Fighter's Generation PlayStation 2 discs, and the Street Fighter Zero 3 Upper NAOMI GD-ROM CHD with its sfz3ugd.zip PIC archive.
  • For each version, add your own PSP disc image: the USA Street Fighter Alpha 3 MAX for the USA build, and the Japanese Street Fighter Zero 3 Double Upper for the Japan build. Each version is built only when its disc is given. No game data is hosted.
  • The Arcade Patches builder app prepares Python and its dependencies and runs the kit against your files. The kit builds Upper first, then MAX. Use new, empty work and output folders with at least 8 GiB free.
  • The kit writes separate HBMAME, FBNeo and MiSTer outputs, with sfa3max for USA and sfz3dup for Japan.
  • On MiSTer, copy the contents of the generated mister/ folder to the root of your SD card. The game entries go under _Arcade/_Arcade Patches/_Restorations.
Full instructions are on the project page.
This is a release candidate. Bug reports and suggestions are welcome right here. Tell me which region, fighter, ISM and platform you ran, what you did and what you saw. A short video is helpful too.
Fan work, unaffiliated with Capcom.
So I tried using arcade patches to get it to work with the psp files in tact and I get blocked with an error message.
Holy shit. This is so good. Color me impressed! I did not expect this at all.
I did compare with CFC2, and the pixel ratio seems a bit off. heres comparsion, along with ryu. Am I crazy? Am wondering if its because of resolution difference between CPS2 and NAOMI copies
More information can be found (may be useful for you to compare-
View: https://www.youtube.com/watch?v=XdQ0ip9KJCE
Great version with additional characters!
On MiSTer, I get green graphical glitches scrolling down the left side of the screen, as shown in the photo.
With ArcadePatches-0.1.9, whether I select UPPER or MAX, both versions get compiled.
Last night I requested it, and today when I woke up I see it's a reality. Incredible work, bro.
Later I’ll be playing casually, forcing situations against the CPU and in VS, looking for any bugs to report.
On another note, some suggestions for future updates (and for the SFA3 Upper port):
Taking into account what certain KOF or SF2/SFA3 mix hacks do, add a gradient to the health bars based on the ISM, just like in the original games:
- X-ISM → yellow/red
- A-ISM → yellow/green
- V-ISM → yellow/blue
Also, in VS mode, a stage selector — either a visual one like the Ultra SF2 backport, or just text under the character select screen (stage: Japan, Japan2, USA, etc.).
I think the aspect ratio issue has to do with the PSP's 4:3 mode; keep in mind that Alpha Max 3 runs in 16:9 by default, which stretches the image slightly.
Thanks for the photos. That was a bug in the MAX kit, not your files. Besides MAX, the kit also wrote Street Fighter Alpha 3 Upper's files. Your builder already had an earlier Upper build saved, so after building, it refused to save MAX over a different copy of Upper.
The MAX kit is updated: it now writes only MAX's own files, so it installs beside any version of Upper. The game itself is unchanged. Run ArcadePatches Builder again and choose 1; it picks up the new kit. Your last run didn't save anything, so it builds MAX again from the start.
On MiSTer, MAX's install note is now INSTALL-MISTER-MAX.txt, so it no longer replaces Upper's INSTALL-MISTER.txt.
I'm looking into this aspect ratio behavior. Will let you know what I find.
Thanks for the suggestions. Do you have an example you can share? Any other suggestions for an EX version are appreciated. :)
Doh, will get this fixed.
buh, current FBNeo doesnt support it (just downloaded the nightly) and somehow while it runs SFA3Upper CPS2 natively, it wont run in Retrobat, even though I manually updated the core to the current one. Gonna try the HBMAME version.
Ah, HBMAME (even downloading the emu for windows on its own) still didn't like it. Which emu were you trying this on @strygo ?
For some strange reason, I had to update the upper build to the latest version and used the max build and deleted all of earlier builds (which of the fbneo stuff that I'm currently using) and it worked. Tested it out and noticed a few bugs which I'll update this post with either a video or a few pics about it later when I come back home.
I guess HBMAME users have to wait for 0.289.8 to come out.😭
Are you using HBMame as well? I dont have a lot of exp with it, and so far nothing Ive thrown at it (of these conversions/hacks) has worked. FBNeo hobbles along with CPS2 verison of Upper, and plays Strider EX great.
The next version of hbmame will have support.
What problems are you seeing with FBNeo?
W
Within Retrobat, it just doesn't load. I get the ROM not supported "THIS IS NOT A BUG!" screen, or if I try other FBNeo emus within there it does basically the same thing lol. External stand-alone FBNeo just doesn't see the game at all even if ROMs are rescanned.
Whats weird is I got the Retrobat version of FBNeo to boot Alpha 3 Upper once. It gave a lot of "hey this aint gonna work!" pop ups and then booted just fine. After that, it never did it again.
W
Are you able to see what version of FBNeo is being used? The daily build from ~4 hours ago should have support for the latest Upper/MAX builds.
I'm running it on FBNeo right now. When it's on HBMAME 0.289.8 I will try it and report any bugs.
I'll take a look but I know I downloaded one earlier today. I'll check when I'm back home and let you know.
Indeed, there is an issue where, in 4:3 mode, the sprites are compressed vertically, which distorts their aspect ratio; however, if you set the display to 16:9 and enable "full stretch" in FBNeo, the sprites appear correctly
