Street Fighter Alpha 3 Upper (Arcade backport)
So far the game is working fine for me. I tested rc2 in RetroBat using the FBNeo core through its patching feature.
I updated the core first, but rc2 hasn't been added to FBNeo yet, so I used the patch instead. So far, so good!
OK so Ive got an update, I think the patching tool may have an issue with Linux for this specific game. Thats why it says unsupported. The apply.py version does seem to work, and it *looks* like it completed a FBNeo and HBMAME files, but they dont work on stand alone FBNeo (the one I used for Strider EX), and then downloading FBNeo for Retrobat/Batocera still says the game is unsupported. So as of now, I've no way to test if the game works.
Other than the fellas that are burning this to their Darksoft kit or something - how are you guys getting it to run in FBNeo? It wont even show up in the list like Strider EX does (and even then EX shows up as a clone of Strider).
I should have a fix for Linux landing soon. Sorry about that.
For FBNeo, it should hopefully land in the next daily build.
Linux fix is out. Please give it a try.
OK just tried it, still getting an Unsupported error, this is what last-report.txt says
UNSUPPORTED (new) Street Fighter Alpha 3 Upper (CPS-2) / us-fbneo / FBNeo
Requires a supported Python, host or launcher feature. Package environments: darwin-arm64: Python 3.12, linux-arm64: Python 3.12, linux-x86_64: Python 3.12, windows-x86_64: Python 3.13
Evidently my python is 3.14.9 on CachyOS. I used these commands to tell that folder/instance to use 3.13 as required.:
(after ive installed python 3.13)
uv venv --python 3.13
source .venv/bin/activate.fishpython
And then ran python arcadepatches.py
edit: standby - i think I may have found the issue and it has to do with my reading ineptitude. brb
EDIT 2: OK, its currently processing but I found the issue, and I was right - DD's stupid eyes. I didnt realize that for Linux it was requiring 3.12, and Windows wants 3.13. DERP. Im gonna let it run overnight and go get some sleep! Hopefully FBNeo will be updooted by morning or Saturday to check the ROMs.
Success!
I finally found a nightly/linux version/working/standalone-that-doesnt-need-damn-installation version of FBNeo and ran Upper CPS2. FBNeo devs dont like Linux people lol. The 'gui' is basically like DOS lol but it works!
Badass work, strygo, yet again.
Street Fighter Alpha 3 Upper rc3 is available.
  • Fixed the computer-controlled Fei Long sometimes flying out of bounds during his Rekka, and the slowdown on the Las Vegas stage.
  • Fixed Guile’s Level 3 Sonic Hurricane dealing only a few tiny hits, some fighters taking the wrong amount of damage, and Dee Jay’s throws. Guile’s supers have their darkened startup again.
  • Every winning ending was checked against the NAOMI original: final scenes use the original backgrounds, artwork and colors instead of moving fight stages, many ending glitches are fixed, and endings close with a thank-you card.
  • Birdie, Blanka, Dan, R. Mika and Rolento fight Balrog on the evening Secret Point stage, and the missing rival intros are back.
  • Four stage themes play their instruments at higher quality, and Dee Jay’s victory claps sound correctly.
  • Fixed world-map, portrait, victory and select-screen colors, and the USA version uses the restoration’s taller win-quote panel.
The first post has the full list: Download rc3 and full instructions
Both builds have new checksums, so rebuild each region you use with the rc3 kit, or update through ArcadePatches Builder, using the same game files as before. On a computer, you need an HBMAME or FBNeo build with the rc3 Upper sets.
This is a release candidate. Thanks for the reports! Please include your region, fighter, ISM and platform, and the steps to reproduce any problems.
Awesome work man.
Im curious, I know I mentioned something like this in the regular Upper mod thread, but would there be a way to add the other 4 characters that came out for the other portable versions like Maki, Yun, Eagle and Ingrid?
edit: this would effectively make this Upper version the "Ultra Street Figher II Turbo" of SFA3.
Love your work and have been following a few projects for a while - I can finally post!
Using RC3 and FBNeo Fei Long’s Rekkaken (any ism) has the dust clouds animate in the wrong position. I saw a fix posted for when the cpu does it (screws up his positioning and moves him backwards) but haven’t been able to fight him again to see if that is still the case.
Thank you!
Thank you!
Thanks! This bug will be fixed in the next version.
No thank you! Also - a smaller item - on FBNeo it recognizes the new RC3 as RC2. Look at the date here and top of FBNeo.
That's strange. FBNeo correctly recognizes RC3 on my end, as you can see in the attached screenshot.
Wow interesting! I’ll do a reinstall of FBNeo and see if that makes a difference.
Hi, I'm a Korean player. What I want most is a Street Fighter Zero 3 that runs perfectly on CPS-2, so I've been testing your Upper kit with the help of an AI, and along the way we found some defects in the kit. I'm writing them up here in case they're useful to you. Contact: zuneho@naver.com
I know the release notes say Dramatic Battle and the other console modes are not included. But the arcade code for them is still in the ROM. Once the cabinet's play counter unlocks them, they can be entered normally (kick x3 + Start for Dramatic, punch x3 + Start for Survival). With the original 32 fighters they work fine. With the added fighters they break, because several tables indexed by character ID still have only the original 0x20 entries. All four problems below come from that, and each fix is small.
Test conditions: Japan build of rc3 (sfz3up / sz3upj), the FBNeo nightly libretro core running headless. Addresses are 68000 addresses in the decrypted program. I did not check the USA build, real CPS-2 hardware or MiSTer. One note on encryption: data read with a PC-relative operand (e.g. move.b tbl(pc,d0.w)) goes through the opcode decryption path, so those tables have to be written encrypted, while tables read through (An) are plain.
Report info (as you asked in your rc3 post):
  • Region: Japan (sfz3up rc3)
  • Platform: FBNeo (libretro core in RetroArch on PC; I also used the same core headless for testing)
  • ISM: Z-ISM (the default; I did not try the others)
  • Fighters: Guile, Fei Long, Dee Jay, T. Hawk, Shin Akuma, boxer (0x25)
  • Steps: unlock Dramatic Battle (play counter / EEPROM unlock stage 4) -> kick x3 + Start -> pick an added fighter -> (1) the screen corrupts or the game resets right away (Guile every time) (2) wrong face and missing names on the HUD (3) after beating the final Bison, Guile stalls on a green screen for about 3 minutes and Shin Akuma resets the game.
  1. Dramatic Battle: wrong CPU partner, screen corruption or reset (Guile corrupts immediately)
0xBA10: jsr $1BDA6 / andi.w #$20,d0 / add.b $102(a0),d0 / move.b $BA26(pc,d0.w),$102(a1) Table 0xBA26 is 0x20 entries x 2 copies. For IDs 0x20-0x25 the lookup reads code bytes past the table as the partner ID. The partner color table at 0xBC0C-0xBC54 (d0 = id + 0/0x20/0x40, move.b $BC56(pc,d0.w)) has the same problem.
Fix: point 0xBA10 to a new routine that masks with andi #$40 and uses a 0x40-entry x 2 table. For colors, change the addi at 0xBC20/0xBC32 to #$80 and the one at 0xBC46 to #$40, and point 0xBC4A to a new table of 0x40 x 3 entries. I took the values from the NAOMI ZERO3ROM.BIN (gdl-0002, after DES decryption): partner table at 0xFD154 (0x26 entries), color table at 0xFD23C (0x26 x 3): partner: 01 00 11 04 03 0b 18 1b 15 0f 16 05 19 1d 1c 09 1a 02 03 02 18 08 0a 00 06 0c 10 07 0e 0d 1f 1e 03 23 20 21 17 08 (Guile->Charlie, Fei Long->T.Hawk, Dee Jay->Guile, T.Hawk->Fei Long, Shin Akuma->Evil Ryu, boxer(0x25)->Birdie. Entries 0x12 and 0x14 also differ from the original 0x20-entry table.)
  1. Dramatic Battle HUD: wrong face (Guile shows Chun-Li), missing faces and missing names
In Dramatic, the team's active fighter alternates on the P1 side of the HUD. That drawing goes 0xB8FA2/0xB90B0 -> 0xB92FA (picks 0x400 or 0x800) -> 0xB972C (face) and 0xB9506/0xB953E -> 0xB957A (name).
  • Face: 0xB972C looks up the 8-byte records at B996C/B9A7C using id*8. The table has 0x22 records, and record 0x20 is the start-button Chun-Li face, so Guile gets Chun-Li's face and 0x21+ read past the end (off-screen coordinates). The normal-mode path (0xB95E2 -> EF864/F8B7C/E86CE) has your hooks; this path doesn't. The round-start init at 0xB96B4 (tables B9B8C/B9C9C, used when $138=6) has the same issue.
  • Name: your hook chain at 0xB957A (EF846 -> F8B3E -> E8688 -> EDBF8 -> E7EEC) chooses the x position from $101(a3) (the fighter's side). The Dramatic partner lives at 0x800 with $101=1, so its name is drawn at the P2 position (off-screen) even though it should appear on the P1 side. Fix:
  • 0xB972C and 0xB96B4: add the same branching as the normal path (keep the start-button Chun-Li as 0x20; 0x25 -> 0x15; 0x24 -> 2 (Akuma's face); 0x20-0x23 -> a new table built from your normal-path records A3E000/8, B7AB18/20, BED060/8, C6D080/8). For B96B4 only, shift x by the Dramatic offset (P1 -0x10, P2 +0x10, constant across all 0x22 original records).
  • 0xB957A: build a temporary struct on the stack (copy $102; set $101 = 0 if a1-a6 == $56, otherwise 1), point a3 at it, call the hook chain, then restore a3. The chain reads only $101/$102 from a3. (Writing $101 directly while masking interrupts with ori #$700,sr reset the game, presumably because it runs in user mode.)
  1. Dramatic / Survival clear: Guile stalls on a green screen for about 3 minutes, Shin Akuma resets the game
After a clear ($149 = 4 for Dramatic, 6 for Survival -> table 0x25DCA -> both go to 0xAD1F8), a pose object (type 0x26, subtype 0x14, handler 0x95A78) is created for each team member. At 0x95AEE it looks up the owner's ID in the animation base table 0xDE6A0 (0x20 entries; after that come values like 0xFFFD0000) and in the action table 0x95B2E.
  • Guile: runs a garbage animation, the main loop becomes about 30x slower, and the green CONGRATULATIONS background sits for roughly 11,000 frames before the credits.
  • Shin Akuma: right after the KO on Bison the game resets to the boot RAM check, so you return to the title with no ending. Fix: point 0x95AEE to a new routine. For IDs 0x20-0x25, use your existing table at 0xC753B8 (12 bytes per fighter: anim table pointer, -, action<<24; the one used by 0x94720/E896A) and call jsr $1B6E0 / jmp $1B4EC; for other IDs, return to the original code at 0x95AF8. There is no Dramatic-specific pose for the added fighters, so this substitutes the win pose. After the fix, both Guile+Charlie and Shin Akuma+Evil Ryu reach CONGRATULATIONS -> credits -> THANK YOU FOR PLAYING. Survival uses the same routine, so the fix covers it too, but I could not reach a Survival clear headlessly, so that part is untested.
  1. Still unchecked I listed every place in the program that reads a table indexed by $102/$132. 53 of them still use the original 0x20-entry tables; most are move tables keyed on the opponent's ID. None of them showed a visible problem, but I haven't verified them. I can send the list if it helps.
All four fixes are small hooks placed in free space in 04c (0xFFA00-0xFFFFF). If it's useful, I can send the build scripts (Python) and the exact bytes. Thanks for the great kit.
