Asure
F
It's not your fault, but its a valuable lesson to others out there.The roms I sent you are from the original game. the roms on the rack, unfortunately I didn't make a copy![]()
I will try to recover the roms. next week post the result hereIt's not your fault, but its a valuable lesson to others out there.
If you got weird shit, back it up!
Just curious if you checked through hbmame checksums also. Many more hacks end up there.
friend, I managed to recover the roms from the original rack. Give it a try and post the result here.I do see the two different roms, but no strange fireballs. The CRC is different, they appear to not have been dumped before/added to mame, so there's something different, but it's not working any different in the emulator.
Which player to use? I tried Ken and Ryu, both normal.
I managed to solve it by re-recording the eprom 29 and 36 of the pcb and the hadouken was corrected again
Unfortunately, this is a romset with 29 & 36 from original SF2, maybe the roms.rar file is the wrong one?friend, I managed to recover the roms from the original rack. Give it a try and post the result here.
replace only eproms 29 and 36 that will work. for me it worked perfectly on cps1.Unfortunately, this is a romset with 29 & 36 from original SF2, maybe the roms.rar file is the wrong one?
30D and 37D are indeed hacked, but they do not change anything in the game.
They probably need 29 & 36 to have the magical fireballs..
Can you check 29 & 36 from your hacked dump at this site?
http://romident.coinopflorida.com/
Maybe you get lucky and there is some dump of it still in your harddisk.![]()
This
