SOLD Sub Panel for Vewlix/Chewlix *(OUT)
jermz1
Upstate New York
Sub / Aux Panel for Chewlix/Vewlix
Redirecting post, since it started out as a project into a product.
Will be moving to Korea by the end of the month.
My stuff will be packed up feb 24. If you plan to place an order, please do so before then.
thanks
Interested in one (black, no text) -- but I'm curious, has anyone found a volume controller that uses 1/8th jacks, or will I need to buy adapter cables for that as well to work with in-built amp?
@harih no idea if anyone has, you could probably use an adapter. Most of chewlix owners have a built in amp that accepts red white. Unless you a different set up that requires a 1/8th jack input.
I’m not too sure what you’re after but I used one of these (from a different seller) in my Lindbergh console conversion.
https://www.ebay.com.au/itm/303443467888
