Super Street Fighter II EX (Enhanced version)
Amazing work, this really is the definitive version of Super Turbo for me. Only 3 minor things that would make it perfect
1. Ability to go "back" in console mode once you're at the mode select screen (Arcade, VS etc) - minor point but would be nice,
2. Easy select for super characters - can be selected via code but nice to have
3. Music select - bit like the PS2 version, would be nice to be able to select arrange mode without going into the arrange CPS+ version
BTW - I've rebuild the CPS1.8+ but the arrange track still doesn't end when you press start.
1. You should be able to go back from versus mode using LK. On the select screens, you should be able to pause and quit. Did you have something else in mind?
2. This is to make the timing easier? Do you have a button combo in mind?
3. I’ve been thinking about an optional build option that lets you bundle audio with the EX version, similar to how FF and USF2 work. This would apply for SSF2EX, SFAEX, and SFA2EX. I assume you’d like that?
I’ll look at the 1.8 issue. A core change was needed, can you check that you copied over all necessary files?
