kazuo
When I got it, it was suicided. No sign of corrosion or leaks whatsoever, very clean board. Installed an Infinikey and it came back to life, but I'm seeing some weird rows of "dots" (pixels) almost in a grid pattern across the screen during startup, the warning screens, and the intro. However, during actual gameplay (character select, stage/character intro, gameplay), it works flawlessly. Memory test passes with everything showing "OK".
Obvious stuff I already did: visual inspection (no corrosion, no physical damage), pushed down on all the socketed chips to ensure they're seated, checked the "A" board for bent pins or other damage and blasted it with deoxit. No change.
Anyone have any ideas?
Thanks!
Thanks!
