Srayer
UPDATE: A redesigned version is shown below: https://www.arcade-projects.com/thr...arcade-system-mean-well-psu.32693/post-453328
I got a 3D printer for Christmas, and I was looking for a meaty project to help me learn CAD. So, I decided to design and print an enclosure for my HAS with a JAMMA extension cable and MeanWell RT-125A PSU. I wanted a small, clean enclosure with controller ports on the front, and all of the other I/O on the back. I also wanted it to be both a supergun and a bench test box that I could hook up to an arcade monitor and speakers. So, in addition to line-level audio and consumer RGB out, I wanted dedicated connectors for JAMMA video and audio, as well as a 120v socket for powering a monitor. Here's what I ended up making:
This design directly uses the JAMMA connector from the HAS, but uses panel-mount components and cables to connect everything else. There's also a window to view the HAS OLED. Is this a cost effective solution? No, but I like it and had fun building it. Is this something you should build? If you don't already have a HAS and Mean Well RT-125A, then almost certainly not; there's probably a cheaper pre-built solution for you. If you already have those, then maybe? Depends on whether you want to spend a bunch of time and some money to build it. I think it's neat; maybe you do, too.
I won't be providing a print profile for this enclosure, since I've redesigned it and made it simpler thanks to the great feedback in this thread. See: https://www.arcade-projects.com/thr...arcade-system-mean-well-psu.32693/post-453328
And here's the BoM. Note that many of these things can be bought from AliExpress for less than I paid on Amazon:
- HAS, JAMMA extension cable, and Mean Well RT-125A (linked above, but hopefully you already have these)
- Male 8-pin mini-DIN connector: https://www.digikey.com/en/products/detail/adam-tech/MDP-008/10222603
- Female 8-pin mini-DIN connector: https://www.digikey.com/en/products/detail/same-sky-formerly-cui-devices-/MD-80PL100/500830
- White RCA jack: https://www.digikey.com/en/products/detail/switchcraft-inc/BPJF03X/1556284
- Red RCA jack: https://www.digikey.com/en/products/detail/switchcraft-inc/BPJF02X
- Female 3.5mm stereo audio jack: https://www.digikey.com/en/products/detail/switchcraft-inc/35PRM3/6695851
- Male 3.5mm stereo audio jack: https://www.amazon.com/dp/B09SZ5H9MJ
- Female 15-pin high density D-Sub (VGA) connector: https://www.digikey.com/en/products/detail/amphenol-cs-fci/10090770-S154ALF/2350291
- Power switch: https://www.digikey.com/en/products/detail/e-switch/RA1113112R/3778055
- 120V AC Socket: https://www.amazon.com/dp/B01JR7QFQO
- 120V AC power cord receptacle: https://www.amazon.com/dp/B07PVP7GL2
- 60mm fan: https://www.amazon.com/dp/B0DJNX4CX4
- 60mm fan grill: https://www.amazon.com/dp/B01MAXR4G9
- DB15 extension cables: https://www.amazon.com/dp/B0D95BSP16
- 4 pin audio terminal block: https://www.amazon.com/dp/B08YMZ88Z5
- Pushbutton (6): https://na.suzohapp.com/products/pushbuttons/49-0577-00
- M3 threaded brass heat inserts: https://www.amazon.com/dp/B08BCRZZS3
- Long D-Sub hex screws: https://www.aliexpress.us/item/2251832796614139.html
- Various M3 screws, washers, and nuts
- A pair of M2 screws, washers, and nuts to mount the female mini-DIN connector
