sorry got home at 4am was trying to sleep AND MY COUSIN AND UNCLE ARE SLAMING DOORS. LOL. This happens in both Sega blasts
what would I meter sorry I'm semi still learning this stuffthat is 100% a sync issue. time to break out the multimeter....
It's worth mentioning -5V is also used for powering logic chips on classic games (late 70's/early 80's) and is in fact vital for those boards (lack of any of +12V/+5V/-5V leads to the destruction of CPU/RAMs in a matter of minutes).-5 has nothing to do with sync, -5 is used on the sound circuit of some boards
Ensure the video GND wire is connected on your cab and on the board.
verify the monitor wiring starting with the video ground.it's likely the video ground isn't connected and needs to be connected.
Connect video groundOh hey, my blast also won’t sync with my sys18 board! I’ll fiddle with it in a bit and see what fixes it.
blasts loom 001 have video ground wired at least that what the pinout saysConnect video groundOh hey, my blast also won’t sync with my sys18 board! I’ll fiddle with it in a bit and see what fixes it.![]()
If the Blast does indeed have a good video ground then it could be that simple.It might just be a matter of adjusting your remote board. Taito F3 in my Astro City displays a similar image until I adjust V Hold, from memory.
Lol, no pressure.I trust @ekorz to get to the bottom of it.
You got a system18 board? I get continuity tone between pins 1 and 14. Unless I'm missing the point on this suggestion which I totally could be... I know some pcb's don't have them connected so you gotta have it in your cab wiring (yeah?). Still new to cab stuff... Anyway...Connect video ground![]()
winner, or close enough.
