Finally, multi System 16B (Sega)Does anyone know if system16A games be converted to system16B ?
Thinking specifically about: Fantasy Zone
Yes.Does anyone know if system16A games be converted to system16B ?
I fixed it and released the files here.I know about the buggy system16 version from the PS2, just wondering if the original was a possible target
It's just a matter of moving jumpers.Is it possible to make Cotton playable on 171-5521?
My Tetris rom board is 171-5521. Everyone says it is identical to 5704, but I don't find any info to mod this board.
No. One has tile banking enabled for the sprites, the other for the tile ROMs.Is it possible to make Cotton playable on 171-5521?
No, it isn't. They are wired up differently and while very close, they're not identicalIt's just a matter of moving jumpers.Is it possible to make Cotton playable on 171-5521?
My bad. Is it a challenge then?No, it isn't. They are wired up differently and while very close, they're not identical
The actual rom board would have 171-5521 printed on it, the sticker doesn’t really identify the rom board. And I don’t see a version of Shinobi in MAME that works on that rom board. That’s not to say that it isn’t possible at all, but it is to say that you’d be doing more work than just a rom swap if it was, and I don’t think anyone has published that work.Hi there!
8034-7002-02 label on my Dynamite Dux Rom Board.
Can I convert this board into Shinobi?
The thing is there are so many combinations possible... And now with the multi is it still worth bothering?The actual rom board would have 171-5521 printed on it, the sticker doesn’t really identify the rom board. And I don’t see a version of Shinobi in MAME that works on that rom board. That’s not to say that it isn’t possible at all, but it is to say that you’d be doing more work than just a rom swap if it was, and I don’t think anyone has published that work.
Hmm I tried to make a Fantasy Zone 2 conversion from Wrestle War, using the 5704 romboard. (and the bigger rams).Different games require different EPROMs, that's why the confusion unfortunately. The only EPROMs that are the same across all games are the main program which are always 27C1000.
Sound program on every game I've seen is a 27C256 as well but could well be a 512 on some games.
Thanks for the tip! Ill check it out tonight. I also realised that the chinese seller sent me 250ns eproms instead of the 120ns that I requested to buy... Havent seen any slower than 200ns so it might even be to slow eproms thats causing trouble... AHhh the headache with all china-ebay/aliexpress orders. Almost every single time its something... dead, fake, rebranded, wrong, semi-working chips.. seems that even thou I generally dont buy the cheapest ones, i still get the same shityou can figure it out using a multimeter:
the 27c010/27c1001 (JEDEC)
CE = Pin 24
A16 = Pin 2
the 27c301/27c1000 (non-JEDEC)
CE = Pin 2
A16 = Pin 24
basically A16 should be shared between all of the ROMs in the same group, while CE will either be tied to ground or shared with only 1 other ROM.
In my experience on the System 16 ROM boards it either uses ALL 27c010 or ALL 27c301, I've not noticed any that are mixed.
