System 32 desuicide and conversions: all games patched and released!
Is there a working link anymore for the decryped sets? I have a suicided Sonic here that needs fixing.
Thanks - just pull the module and replace 2 chips I'm led to believe?
I've done up a schematic of the 834-7739-02, and put in the modifications required to jumper it to a 837-7429-01. All IC naming, and layout matches the 834-7739-02, and all red text is the associated value for 837-7429-01.
Please note though, this does not make it 1-1 compatible with a 837-7429-01. It seems that we can convert a 834-7739-02 to a spiderman, but I can't confirm this is the case for all games (most likely yes, but no guarantee's), this is because of CNH A6 and B6, and how it affects the associated latches they are connected to.
Anyways, the IC mapping table is the following
RM 834-7739-0xSM 837-7429-0x
74F374PCIC36IC5
74F374PCIC35IC12
74F374PCIC34IC19
74F374PCIC33IC4
74F245NIC32IC2
74F245NIC31IC3
74F245NIC30IC10
74F245NIC29IC17
74F245NIC24IC20
74F245NIC23IC8
74F245NIC15IC15
74F245NIC4IC1
74HC373E
74HC373E
74HC373E
74HC373E
And the schematic I did up is here. Hope this can help someone in the future. Please let me know if anyone here wants to build a replica of this board, and I will share my EasyEDA project with you.
Schematic (too large to attach here) - https://drive.google.com/file/d/1mjuxLnCjjhtQDSfYQaLMohBVQo5Hye-t/view?usp=sharing
The SVG above doesn't seem to load properly for me without downloading it first, and opening it from local disk.
Bump. I know the system 32 multi and system 32 single boards use a nec v60 vs a nec v70.
Is there any downside/issues to repurposing a multi link game as a single?
Has anyone used a SVF ROM board for a conversion and if so did you keep the SVF chips? I have a j-league here I want to turn into SVF and it would be nice to put originals on.
Hello, I've been trying to get a Segasonic conversion working for quite a while, but keep running into a bug where the game runs fine on an initial play but a second play (after a game over and back to title screen) will start on the ice stage, a third play will start on the next stage, and so on. I've confirmed this is a behavior tied to the decrypted ROMs by booting the game in MAME (as opposed to an issue with my System 32 board). I see on this thread that an updated version of the decrypted ROMs was produced, but do not see links to those files anywhere online. Does anyone here have access to those files? Thanks!
