Does it give you coin error when you flash games or when you press the coin button? I know a few boards (dont remember sorry back in 2017) which would give yo coin error if you kept the coin button pressed for a bit of time. Since coins generally passed through with just one click if you keep the button pressed for a longer period the system thinks the coin mechanism has jammed and spits out a coin error. Could be something different too though. Try pressing the coin button for a very shot period of time. Maybe think you are typing a morse code when you click the coin buttonGuys,i have a question and i don't know how to solve it. Few days ago the system starts to give me "Coin Error" when i flash games. I'm using encrypted set and i've tried 2 micro sd cards until now (both acts in the same ways). I've read some posts and i don't know how to get on the service menu to clear the memory. Many thanks in advance for all![]()
Yes ... i think this is the puzzle. It's not the HAS supergun button (works great that buttons) ... maybe was from my neo geo controllers. I notice one of them give coins after a very slight touch. I play puzzle bubble after i finish the game and i've used some coins ... no problem at all, after that i flashed the Elevator Action 2 (again...ok), after that i've flashed Darius (ok)Maybe it sounds obvious, but if you are running it in a cabinet, there might be an error with the coin mechanism. If you use a supergun, the coin signal might be stuck.
I used the test buttons , no problems there (i think the problem it's from my one of the Aes controllers ... select button - on Cps2 that controller act ok, but F3 system i think it's little bit tender)I forget, but I take it the "test" or "service" buttons won't do?
Click this link, Not that cheap but not to high of a priceTell me where to find these mobos! Don't see any on eBay nor the FS threads at the moment.
You mean ThomasM, bought a few boards from him over the past year or so, including F3I ended up buying one from an Italian user on arcadeotaku a couple weeks ago. It's still in transit and it has some issue, but at the time there was nothing available anywhere else. Oh well...hindsight.
if it's a cart issue ... doesn't matter because if you'll use the DS multi kit , you'll need only the cartridge shellYep, that's the person. He actually mentioned the specific issue it had, but I don't know if it's the cart or mobo. Guess I'll just have to wait and see.
ThomasM can be somewhat sneaky. He will pair up a non-working cart with a non-working motherboard. So don't be surprised if you're having problems with both.Yep, that's the person. He actually mentioned the specific issue it had, but I don't know if it's the cart or mobo. Guess I'll just have to wait and see.
Thanks for the tip about that seller. I was going to buy a few games from him, including a Bucky O'Hare, but the way he was trying to sell things to me, well it made me suspicious so I canceled the whole deal. Good to know I probably dodged a bullet there.ThomasM can be somewhat sneaky. He will pair up a non-working cart with a non-working motherboard. So don't be surprised if you're having problems with both.Yep, that's the person. He actually mentioned the specific issue it had, but I don't know if it's the cart or mobo. Guess I'll just have to wait and see.
