Taito F3 Multi Label $25 Donation To Create These
So are you guys with labels removing the old one first before you add the new one?
And HOW are you removing it?
I thought about putting the new label on top of the original, but the original label was not put on very clean, not centered and not straight in the available space...
My OCD couldn't handle that so I teard it off starting from one of the edges.
After that wipe the cart with some cleaner/degreaser and put the new one on.
As my donor case is from a Taito Power Goal, I don't care.
Wouldn't do it to more valueable games ;)
some ideas;
I'd actually be fine with the word prototype in the clear space below the F3 logo.
Actually I see there are PNG files for a prototype rubber stamp image on the web. That would be cool. Maybe a an angle as if someone had stamped it by hand. :)
can you send me that file or the link to it?
I use Ronsonol Lighter Fluid to remove labels/stickers from plastic.
Once removed, I then use Isopropyl Alcohol to further remove/clean-up the lighter fluid residue. ;)
Works better than Goof-Off, and it won't damage plastics like Acetone.
You should just get one made yourself and stamp it for real. they're pretty inexpensive: https://www.rubberstampchamp.com/ca...hL0K_eoqn3Mef77UUrB8a7joyxMpEtgAaAqEPEALw_wcB
I had a "self inking" return address stamp made years ago for like $6 shipped, it makes a satisfying "ker-chunk" i use it all the time; good investment :)
you could also print and cut out a stencil and hit it with a few quick bursts of red paint
The F3 label on my case left not a single bit of residue after removing, so if you peel it off carefully it's fine with just some degreasing after :)
I got a quote from my local copy shop.
If I order the stickers in quantities of 10, I can offer them for €11 shipped worldwide.
Note; this is costprice, no profit in it for me :)
So if a few people who missed the initial batch show interest, I'll have some printed next week
