Tailsnic Retroworks
Hi. I am experiencing this error on updating to 2011 modbios. Can someone tell me where do I have to look? I have checked every chip and TTL for flying legs
What of them is it? For changing it@rester159 is having the same problem with his G-NET board. He’s shipping it to me to look at but my theory is that the flash chip that holds the BIOS is bad.
The info that is flashed into the 27c800 is the same when updating the 16mbit tsop?Ugh, that's unfortunate. What if you program the modded BIOS to the flash chip before soldering it to the board so that the board doesn't ever have to reprogram it itself?
Yes, should be the same.The info that is flashed into the 27c800 is the same when updating the 16mbit tsop?
Thanks for the tip. I'll try itHi!
I had already had this problem of flash impossible to flash directly the new chip on my XGECU T56 LH28F160S5T-L70A, as with the chip LH28F160S3T-L10A for the Bios Naomi impossible to program directly, I really need this method because the location of the TSOP 48 and damaged
you need a NOR/Flash 56-TSOP adapter instead of Flash NAND that I can't find
on my side I took this one and it worked in flash mode with M27C800, the jumper J1 configured and everything worked
https://fr.aliexpress.com/item/1005...t_main.20.54005e5bT4xrCE&gatewayAdapt=glo2fra
Then PGM 28F004 is for sound or is for something more between programming the bios nand?On the G-NET it's only the sound files which are FLASHed the program runs from the CF itself.
My bad, sorry. Yeah, PGM flash is in the YAMAHA section.There is no NAND only FLASH, this is from the MAME layout the pgmflash might be the sound code program ?
INTEL_E28F400B(config, "pgmflash"); // U27
INTEL_TE28F160(config, "sndflash0"); // U29
INTEL_TE28F160(config, "sndflash1"); // U55
INTEL_TE28F160(config, "sndflash2"); // U56
@ShootTheCore Did you archieve to repair that error?
The board only just arrived last week. I haven’t had a chance to start on it yet.
